주요 콘텐츠로 건너뛰기
MSI GE62 Apache Pro 004 Screen Replacement
필요한 것
  1. MSI GE62 Apache Pro 004 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Screen Replacement: 2 단계, 이미지 2개 중 1개 MSI GE62 Apache Pro 004 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate by pulling away from laptop
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Screen Replacement: 3 단계, 이미지 3개 중 1개 MSI GE62 Apache Pro 004 Screen Replacement: 3 단계, 이미지 3개 중 2개 MSI GE62 Apache Pro 004 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Screen Replacement, Screen: 4 단계, 이미지 2개 중 1개 MSI GE62 Apache Pro 004 Screen Replacement, Screen: 4 단계, 이미지 2개 중 2개
    • Open the laptop up as if you were going to use it.
    • Wedge a spudger in between the screen bezel and work it around to separate it.
  5. MSI GE62 Apache Pro 004 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the screws holding in the screen at the corners with a PH1 screwdriver.
    • Be very careful as the screen may tilt forward so make sure your hand is right is on the screen when the screw comes off.
  6. MSI GE62 Apache Pro 004 Screen Replacement: 6 단계, 이미지 3개 중 1개 MSI GE62 Apache Pro 004 Screen Replacement: 6 단계, 이미지 3개 중 2개 MSI GE62 Apache Pro 004 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the bezel from the screen.
    • Remove the two screws located at the bottom of the screen using the PH1 screwdriver.
결론
작성자
1다른 기여자 명과 함께
Samer Soukieh
회원 가입일: 02/19/18
209 평판
안내서 1개를 작성함
USF Tampa, Team S15-G5, Boczar Spring 2018 USF Tampa, Team S15-G5, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 2,294
