주요 콘텐츠로 건너뛰기
MSI GE62 Apache Pro 004 Web Camera Replacement
필요한 것
  1. MSI GE62 Apache Pro 004 Web Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Web Camera Replacement: 2 단계, 이미지 1/2 MSI GE62 Apache Pro 004 Web Camera Replacement: 2 단계, 이미지 2/2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Web Camera Replacement: 3 단계, 이미지 1/3 MSI GE62 Apache Pro 004 Web Camera Replacement: 3 단계, 이미지 2/3 MSI GE62 Apache Pro 004 Web Camera Replacement: 3 단계, 이미지 3/3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Web Camera Replacement, Web Camera: 4 단계, 이미지 1/1
    • Flip over the laptop and open it.
  5. MSI GE62 Apache Pro 004 Web Camera Replacement: 5 단계, 이미지 1/3 MSI GE62 Apache Pro 004 Web Camera Replacement: 5 단계, 이미지 2/3 MSI GE62 Apache Pro 004 Web Camera Replacement: 5 단계, 이미지 3/3
    • Slide a metal opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
  6. MSI GE62 Apache Pro 004 Web Camera Replacement: 6 단계, 이미지 1/2 MSI GE62 Apache Pro 004 Web Camera Replacement: 6 단계, 이미지 2/2
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. MSI GE62 Apache Pro 004 Web Camera Replacement: 7 단계, 이미지 1/2 MSI GE62 Apache Pro 004 Web Camera Replacement: 7 단계, 이미지 2/2
    • Locate the WebCam on the middle of the device.
    • Slide a metal opener tool to remove the Webcam
결론
Majid Al Hashmi
회원 가입일: 02/13/18
283 평판
안내서 2개 작성하였습니다
USF Tampa, Team S15-G5, Boczar Spring 2018 USF Tampa, Team S15-G5, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 9
전체 시간: 826
