주요 콘텐츠로 건너뛰기
MSI GE62 Apache Pro 004 Web Camera Replacement
필요한 것
  1. MSI GE62 Apache Pro 004 Web Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Web Camera Replacement: 2 단계, 이미지 2개 중 1개 MSI GE62 Apache Pro 004 Web Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate by pulling away from laptop
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Web Camera Replacement: 3 단계, 이미지 3개 중 1개 MSI GE62 Apache Pro 004 Web Camera Replacement: 3 단계, 이미지 3개 중 2개 MSI GE62 Apache Pro 004 Web Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Web Camera Replacement, Web Camera: 4 단계, 이미지 1개 중 1개
    • Flip over the laptop and open it.
  5. MSI GE62 Apache Pro 004 Web Camera Replacement: 5 단계, 이미지 3개 중 1개 MSI GE62 Apache Pro 004 Web Camera Replacement: 5 단계, 이미지 3개 중 2개 MSI GE62 Apache Pro 004 Web Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Slide a metal opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
  6. MSI GE62 Apache Pro 004 Web Camera Replacement: 6 단계, 이미지 2개 중 1개 MSI GE62 Apache Pro 004 Web Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
    • Do not force off. Front screen panel is thing and can break or crack very easily.
  7. MSI GE62 Apache Pro 004 Web Camera Replacement: 7 단계, 이미지 2개 중 1개 MSI GE62 Apache Pro 004 Web Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the WebCam on the middle of the device.
    • Slide a metal opener tool to remove the Webcam
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
4다른 기여자 명과 함께
Majid Al Hashmi
회원 가입일: 02/13/18
283 평판
안내서 2개를 작성함
USF Tampa, Team S15-G5, Boczar Spring 2018 USF Tampa, Team S15-G5, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 11
전체 시간: 1,007
