주요 콘텐츠로 건너뛰기
MSI GE70 2PE Apache Pro Keyboard Replacement
필요한 것
  1. MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Insert iFixit opening tool as shown in the picture to pry up on the keyboard guard.
    • Remove the keyboard guard.
  2. MSI GE70 2PE Apache Pro Keyboard Replacement: 2 단계, 이미지 3개 중 1개 MSI GE70 2PE Apache Pro Keyboard Replacement: 2 단계, 이미지 3개 중 2개 MSI GE70 2PE Apache Pro Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the iFixit tool under the plastic screw cover.
    • Grab the plastic part with your hand and lift it off the casing.
    • Remove the plastic part to reveal the screws holding the keyboard in place.
  3. MSI GE70 2PE Apache Pro Keyboard Replacement: 3 단계, 이미지 3개 중 1개 MSI GE70 2PE Apache Pro Keyboard Replacement: 3 단계, 이미지 3개 중 2개 MSI GE70 2PE Apache Pro Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Unscrew the five screws located at the top of the keyboard.
    • Use the opening tool to lift the keyboard from its position
    • Be mindful of the ribbon cables when lifting the keyboard from the palmrest.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
mazin
회원 가입일: 09/27/18
133 평판
안내서 1개를 작성함
2가이드 댓글
What about step 4 detaching the ribbon cable?
russell89000 - 답글
yes missing the part of the 2 ribbon cables, one of them (the lighting) is not reachable like this..
you have to take out the battery, and then remove the back cover to reach the ribbon for the lighting
Kim Van Hoeck - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 43
전체 시간: 4,219
