주요 콘텐츠로 건너뛰기
MSI GE72 6QF Apache Pro Fan Replacement
필요한 것
  1. MSI GE72 6QF Apache Pro Fan Replacement, Battery: 1 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Fan Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Fan Replacement: 4 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Fan Replacement: 5 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Fan Replacement: 6 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Fan Replacement, Fan: 7 단계, 이미지 3개 중 1개 MSI GE72 6QF Apache Pro Fan Replacement, Fan: 7 단계, 이미지 3개 중 2개 MSI GE72 6QF Apache Pro Fan Replacement, Fan: 7 단계, 이미지 3개 중 3개
    • If you are replacing only the keyboard, you can skip to step 18, and then skip the WiFi adapter removal step. The CPU fan, m.2 SSD, RAM and WiFi adapter (marked in green) will all come off with the main board, giving you access to the keyboard.
    • Use a Phillips #1 screwdriver to remove the ten 5.5mm screws.
    • Remove the last two 5.5mm Phillips #1 screws, and remove the washers around them.
  8. MSI GE72 6QF Apache Pro Fan Replacement: 8 단계, 이미지 3개 중 1개 MSI GE72 6QF Apache Pro Fan Replacement: 8 단계, 이미지 3개 중 2개 MSI GE72 6QF Apache Pro Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Unplug both of the fan power cords from the laptop using a spudger.
  9. MSI GE72 6QF Apache Pro Fan Replacement: 9 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Fan Replacement: 9 단계, 이미지 2개 중 2개
    • Continue to use the spudger to carefully separate the wires of the power cord from the laptop.
  10. MSI GE72 6QF Apache Pro Fan Replacement: 10 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Fan Replacement: 10 단계, 이미지 2개 중 2개
    • Fully remove the fans from the rest of the laptop.
  11. MSI GE72 6QF Apache Pro Fan Replacement: 11 단계, 이미지 3개 중 1개 MSI GE72 6QF Apache Pro Fan Replacement: 11 단계, 이미지 3개 중 2개 MSI GE72 6QF Apache Pro Fan Replacement: 11 단계, 이미지 3개 중 3개
    • Using a Phillips #00 screwdriver, remove the six 5mm screws.
    • Separate the fans from the silver fan covers.
결론
다른 20명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Tanmay Kumar
회원 가입일: 04/17/17
458 평판
안내서 4개를 작성함
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G4
4 회원들
안내서 8개를 작성함
9가이드 댓글
I can't get the back case off the last bit of it is held on pretty tight. All the screws are out so how do I loosen it?
Aaron Carlston - 답글
Where can I buy new fans?
Aschwin Versteegden - 답글
Where do you buy the replacement fans
customgirl - 답글
I need a link to buy the actual fan itself if you wouldn’t mind I’d greatly appreciate it
dylan davis - 답글
EDIT: The only place I could actually find the fans were on walmart so Ill post the link here -> https://www.walmart.com/search/?query=ms... (I personally bought the blue one that was first I should get it by next friday and Ill try and remember to post if it works or not)
dylan davis -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 102
전체 시간: 25,901
