주요 콘텐츠로 건너뛰기
MSI GE72 6QF Apache Pro Hard Drive Replacement
필요한 것
  1. MSI GE72 6QF Apache Pro Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Hard Drive Replacement, Hard Drive: 7 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Hard Drive Replacement, Hard Drive: 7 단계, 이미지 2개 중 2개
    • Remove the two 5.5mm screws with the Phillips #1 screwdriver.
  8. MSI GE72 6QF Apache Pro Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pull out the hard drive by wiggling it from right to left with your hands until it is removed.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tanmay Kumar
회원 가입일: 04/17/17
458 평판
안내서 4개를 작성함
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G4
4 회원들
안내서 8개를 작성함
1가이드 댓글
I have just bought an MSI GP72VR Laptop and I screwed up and got the model with only one drive, an SSD. It nagged at me that I didn't get the one with 2 drives. Well I happen to build my own desktops and had a spare 500GB Mushkin SSD hanging around and decided, what the heck. I came here and couldn't find the exact model but this is identical for what I want. I have never seen an access like this where you have to remove 19 screws. So I am very happy that this is on iFixit. I removed the screws and couldn't get the bottom removed as shown, I had to go to the other side and then it came off fairly easily. I used a butter knife for the initial pry and that worked well. They had sent the disk holder with the computer so I had no problem installing and I just set it up in Disk Manager. Tanmay, thank you very much for the assist, it is appreciated.
adard745 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 49
전체 시간: 8,470
