주요 콘텐츠로 건너뛰기
MSI GE72 6QF Apache Pro Optical Drive Replacement
필요한 것
  1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: 1 단계, 이미지 1/2 MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Optical Drive Replacement: 2 단계, 이미지 1/1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Optical Drive Replacement: 3 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Optical Drive Replacement: 4 단계, 이미지 1/2 MSI GE72 6QF Apache Pro Optical Drive Replacement: 4 단계, 이미지 2/2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Optical Drive Replacement: 5 단계, 이미지 1/2 MSI GE72 6QF Apache Pro Optical Drive Replacement: 5 단계, 이미지 2/2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Optical Drive Replacement: 6 단계, 이미지 1/2 MSI GE72 6QF Apache Pro Optical Drive Replacement: 6 단계, 이미지 2/2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: 7 단계, 이미지 1/3 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: 7 단계, 이미지 2/3 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: 7 단계, 이미지 3/3
    • Carefully slide the Optical Drive off of the SATA connector.
    • The red marker shows the location for where the retaining screw comes through the back panel to hold the Optical Drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Riley Smith
회원 가입일: 09/22/17
806 평판
안내서 4개 작성하였습니다
댓글 2개
Why do you have to remove the battery first?
Kevin - 답글
So you don’t have power running through it while working on it.
croberts1290 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 1,463
