주요 콘텐츠로 건너뛰기
MSI GE72 6QF Apache Pro RAM Replacement
필요한 것
  1. MSI GE72 6QF Apache Pro RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro RAM Replacement: 4 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro RAM Replacement: 4 단계, 이미지 2개 중 2개
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro RAM Replacement: 5 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro RAM Replacement: 6 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro RAM Replacement: 6 단계, 이미지 2개 중 2개
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro RAM Replacement, RAM: 7 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro RAM Replacement, RAM: 7 단계, 이미지 2개 중 2개
    • When you open the back cover, the RAM will be located as shown in the picture.
  8. MSI GE72 6QF Apache Pro RAM Replacement: 8 단계, 이미지 3개 중 1개 MSI GE72 6QF Apache Pro RAM Replacement: 8 단계, 이미지 3개 중 2개 MSI GE72 6QF Apache Pro RAM Replacement: 8 단계, 이미지 3개 중 3개
    • Press the hinges on the sides of the RAM chip as shown in the picture, in order to unlock it.
    • Carefully, slide it out at a 45 degree angle.
    • Don't press on the hinges too hard.
    • Be careful about the angle at which you're sliding out the chip.
  9. MSI GE72 6QF Apache Pro RAM Replacement: 9 단계, 이미지 3개 중 1개 MSI GE72 6QF Apache Pro RAM Replacement: 9 단계, 이미지 3개 중 2개 MSI GE72 6QF Apache Pro RAM Replacement: 9 단계, 이미지 3개 중 3개
    • Similarly, press on the hinges on the sides of the other RAM chip, in order to unlock it.
    • Some laptop models might not come with two RAM chips, so if that is your case, you can skip this step.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tanmay Kumar
회원 가입일: 04/17/17
461 평판
안내서 4개를 작성함
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G4
4 회원들
안내서 8개를 작성함
1가이드 댓글
Can you put more ram in this laptop like 32gb?
Can you put another ssd?
nojus.zibikas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 25
전체 시간: 5,121
