주요 콘텐츠로 건너뛰기
MSI GE72 6QF Apache Pro SSD Replacement
필요한 것
  1. MSI GE72 6QF Apache Pro SSD Replacement, Battery: 1 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro SSD Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro SSD Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro SSD Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro SSD Replacement: 4 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro SSD Replacement: 4 단계, 이미지 2개 중 2개
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro SSD Replacement: 5 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro SSD Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro SSD Replacement: 6 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro SSD Replacement: 6 단계, 이미지 2개 중 2개
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro SSD Replacement, SSD: 7 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro SSD Replacement, SSD: 7 단계, 이미지 2개 중 2개
    • Remove the single 5.5mm Phillips #1 screw attaching the SSD to the laptop.
  8. MSI GE72 6QF Apache Pro SSD Replacement: 8 단계, 이미지 2개 중 1개 MSI GE72 6QF Apache Pro SSD Replacement: 8 단계, 이미지 2개 중 2개
    • Pull out the SSD by gently wiggling it from side to side until it comes out.
    • If the old SSD you removed contains the operating system, then the new SSD must also contain an operating system.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tanmay Kumar
회원 가입일: 04/17/17
458 평판
안내서 4개를 작성함
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G4
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 10
지난 30일: 37
전체 시간: 8,309
