주요 콘텐츠로 건너뛰기
MSI GP60 2PE Leopard Hard Drive Replacement
필요한 것
  1. MSI GP60 2PE Leopard Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip MSI GP60 2PE Leopard, so that the back is facing up.
  2. MSI GP60 2PE Leopard Hard Drive Replacement: 2 단계, 이미지 1/1
    • Find the unlock tab located on the upper right side of the device, then slide it to the right.
  3. MSI GP60 2PE Leopard Hard Drive Replacement: 3 단계, 이미지 1/3 MSI GP60 2PE Leopard Hard Drive Replacement: 3 단계, 이미지 2/3 MSI GP60 2PE Leopard Hard Drive Replacement: 3 단계, 이미지 3/3
    • Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
  4. MSI GP60 2PE Leopard Hard Drive Replacement: 4 단계, 이미지 1/3 MSI GP60 2PE Leopard Hard Drive Replacement: 4 단계, 이미지 2/3 MSI GP60 2PE Leopard Hard Drive Replacement: 4 단계, 이미지 3/3
    • While holding the release tab, remove the battery slowly.
  5. MSI GP60 2PE Leopard Hard Drive Replacement, Back Panel: 5 단계, 이미지 1/1
    • Flip the device over so the back is facing up.
  6. MSI GP60 2PE Leopard Hard Drive Replacement: 6 단계, 이미지 1/2 MSI GP60 2PE Leopard Hard Drive Replacement: 6 단계, 이미지 2/2
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  7. MSI GP60 2PE Leopard Hard Drive Replacement: 7 단계, 이미지 1/2 MSI GP60 2PE Leopard Hard Drive Replacement: 7 단계, 이미지 2/2
    • Once all four screws are removed, lift the back off.
  8. MSI GP60 2PE Leopard Hard Drive Replacement, Hard Drive: 8 단계, 이미지 1/1
    • Remove the two 5 mm black screws on the right hand side with a Phillips #0 screwdriver.
  9. MSI GP60 2PE Leopard Hard Drive Replacement: 9 단계, 이미지 1/3 MSI GP60 2PE Leopard Hard Drive Replacement: 9 단계, 이미지 2/3 MSI GP60 2PE Leopard Hard Drive Replacement: 9 단계, 이미지 3/3
    • Lift the hard drive, then remove from the device. There is a black strip of plastic attached to make the process easier.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Zoey Calcagno
회원 가입일: 10/04/18
672 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 20
전체 시간: 1,390
