주요 콘텐츠로 건너뛰기
MSI GP62MVR 6RF Leopard Pro Battery Replacement
필요한 것
  1. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: 1 단계, 이미지 1/2 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Battery Replacement: 2 단계, 이미지 1/2 MSI GP62MVR 6RF Leopard Pro Battery Replacement: 2 단계, 이미지 2/2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Battery Replacement: 3 단계, 이미지 1/1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: 4 단계, 이미지 1/3 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: 4 단계, 이미지 2/3 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: 4 단계, 이미지 3/3
    • Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
    • Remove the battery from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordan Buck
회원 가입일: 01/16/20
388 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 1,181
