주요 콘텐츠로 건너뛰기
MSI GP62MVR 6RF Leopard Pro Fans Replacement
필요한 것
  1. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Bottom Cover: 1 단계, 이미지 1/2 MSI GP62MVR 6RF Leopard Pro Fans Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Fans Replacement: 2 단계, 이미지 1/2 MSI GP62MVR 6RF Leopard Pro Fans Replacement: 2 단계, 이미지 2/2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Fans Replacement: 3 단계, 이미지 1/1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Fans: 4 단계, 이미지 1/2 MSI GP62MVR 6RF Leopard Pro Fans Replacement, Fans: 4 단계, 이미지 2/2
    • Remove the eight 4.5 mm screws that hold the heat sink to the motherboard with a Phillips #0 screwdriver.
    • Remove the four 4.5 mm screws holding the fan in place also using a Phillips #0 screwdriver.
    • Watch for the screw hidden under the wires highlighted in the second picture.
  5. MSI GP62MVR 6RF Leopard Pro Fans Replacement: 5 단계, 이미지 1/2 MSI GP62MVR 6RF Leopard Pro Fans Replacement: 5 단계, 이미지 2/2
    • Disconnect both power cables for the fans.
    • Make sure to pinch the power cables. It may require a bit of force.
  6. MSI GP62MVR 6RF Leopard Pro Fans Replacement: 6 단계, 이미지 1/3 MSI GP62MVR 6RF Leopard Pro Fans Replacement: 6 단계, 이미지 2/3 MSI GP62MVR 6RF Leopard Pro Fans Replacement: 6 단계, 이미지 3/3
    • Using the Jimmy tool, remove the adhesive pads securing the fans to the board.
  7. MSI GP62MVR 6RF Leopard Pro Fans Replacement: 7 단계, 이미지 1/1
    • Remove the black adhesive.
  8. MSI GP62MVR 6RF Leopard Pro Fans Replacement: 8 단계, 이미지 1/1
    • Separate the heat sink from the tab on the side holding the fan in place.
  9. MSI GP62MVR 6RF Leopard Pro Fans Replacement: 9 단계, 이미지 1/1
    • Remove the three 3.5 mm screws on each fan holding the fan to the heat sink using a Phillips #0 screwdriver.
결론
Dawson
회원 가입일: 01/16/20
276 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 24
전체 시간: 1,205
