주요 콘텐츠로 건너뛰기
MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement
필요한 것
  1. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2개 중 1개 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2개 중 2개
    • Using the Jimmy tool, pry the front cover off at the seam.
    • The Jimmy tool is the utensil in the first picture in the user's hand.
  2. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four 2 mm screws on the bottom and top corners of the screen using a Phillips #0 screwdriver.
  3. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Using the Jimmy, pry off the unscrewed LCD display.
    • Make sure the black adhesive is out of the way.
    • Don't pull the screen completely off, as the screen will still be attached.
  4. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the ribbon cable by pulling on the bar code tab.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jordan Buck
회원 가입일: 01/16/20
409 평판
안내서 4개를 작성함
3가이드 댓글
Hey Jordan, when reassembling the front cover (which in my case, a GP63 Leopard 8RE, is glued at the bottom) what type of glue should be used? Thanks
Jaime Blasco - 답글
Hi Jaime, two part expoxy (Alraldite) glue should work, otherwise 3M double-sided adhesive tape would work as well.
Jordan Buck -
Hi Jordan,
If the screen is damaged due to the cover itself being bent, do you have any advice?
Thanks
Ainsley - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 37
전체 시간: 1,788
