주요 콘텐츠로 건너뛰기
MSI GP62MVR 6RF Leopard Pro Speakers Replacement
필요한 것
  1. MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Bottom Cover: 1 단계, 이미지 1/2 MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: 2 단계, 이미지 1/2 MSI GP62MVR 6RF Leopard Pro Speakers Replacement: 2 단계, 이미지 2/2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: 3 단계, 이미지 1/1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Speakers: 4 단계, 이미지 1/1
    • Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
  5. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: 5 단계, 이미지 1/1
    • On the front panel near the right speaker, there is a connection from the motherboard to the speakers.
    • Detach the white and black wiring from the clip.
  6. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: 6 단계, 이미지 1/1
    • Peel back the electrical tape holding the speaker wire in place.
    • Remove the speakers from the front panel, pulling upward.
    • Note that the screws holding the two speakers down were already removed during the bottom cover removal.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 12
전체 시간: 314
