주요 콘텐츠로 건너뛰기
MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement
필요한 것
  1. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement, Hard disk drive: 1 단계, 이미지 1/3 MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement, Hard disk drive: 1 단계, 이미지 2/3 MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement, Hard disk drive: 1 단계, 이미지 3/3
    • Remove the eleven 5mm screws with a PH0 bit.
    • Remove the four 2.5mm screws with a PH0 bit.
    • Remove the bottom cover
  2. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement: 2 단계, 이미지 1/2 MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement: 2 단계, 이미지 2/2
    • Unplug the selected white wire located above the hard drive.
    • Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard. Do not break the black cover
  3. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement: 3 단계, 이미지 1/1
    • Unplug the hard drive gently.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mafdy Wahib
회원 가입일: 09/28/17
369 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G4, Nance Fall 2017 USF Tampa, Team S1-G4, Nance Fall 2017 회원
USFT-NANCE-F17S1G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 2,884
