소개
If you have lost either backlight or any loss of pixels in your laptop screen, you may need to replace your LCD screen. In this laptop, you will need to fully remove the screen assembly to get to the screen. The only requirements are a set of laptop tools.
필요한 것
Remove the eleven 5mm screws with a Phillips #1 screwdriver.
Remove the four 2.5mm screws with a Phillips #1 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
