주요 콘텐츠로 건너뛰기
MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement
필요한 것
  1. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement, Motherboard fans: 1 단계, 이미지 1/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement, Motherboard fans: 1 단계, 이미지 2/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement, Motherboard fans: 1 단계, 이미지 3/3
    • Use a Phillips #0 driver to remove the 15 screws that hold the bottom cover:
    • Eleven 2.5 mm length screws
    • Four 5 mm length screws
    • Remove the bottom cover.
  2. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 2 단계, 이미지 1/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 2 단계, 이미지 2/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 2 단계, 이미지 3/3
    • Locate the battery.
    • Locate the battery plug and unplug it carefully
  3. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 3 단계, 이미지 1/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 3 단계, 이미지 2/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 3 단계, 이미지 3/3
    • Locate the Hard drive
    • Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard
    • Be careful not to break the black cover because it can be broken easily
    • Unplug the hard drive
  4. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 4 단계, 이미지 1/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 4 단계, 이미지 2/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 4 단계, 이미지 3/3
    • unplug this wire carefully
    • Unplug the brown wire located next to the previous wire. Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard
  5. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 5 단계, 이미지 1/2 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 5 단계, 이미지 2/2
    • unplug the selected wire. Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard
  6. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 6 단계, 이미지 1/2 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 6 단계, 이미지 2/2
    • unplug the brown selected wire. Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard
  7. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 7 단계, 이미지 1/1
  8. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 8 단계, 이미지 1/2 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 8 단계, 이미지 2/2
    • Locate the selected wire and unplug it carefully
  9. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 9 단계, 이미지 1/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 9 단계, 이미지 2/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 9 단계, 이미지 3/3
    • unplug the selected wires
    • Unplug it gently without causing damage to the wire
  10. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 10 단계, 이미지 1/2 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 10 단계, 이미지 2/2
    • unplug the selected white wire. Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard
  11. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 11 단계, 이미지 1/2 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 11 단계, 이미지 2/2
  12. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 12 단계, 이미지 1/2 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 12 단계, 이미지 2/2
    • remove the selected 2.5 mm screws by PH0 Bit screwdriver
    • Gently unplug the electronic chip
  13. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 13 단계, 이미지 1/1
    • Remove the four 2.5mm screws with a PH0 bit.
  14. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 14 단계, 이미지 1/2 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 14 단계, 이미지 2/2
    • After you remove all the connected wires and unscrew all the screws that holds the motherboard to the laptop, take the motherboard out as shown in the picture.
    • Make sure it is completely diconnected from all wires and screws
  15. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 15 단계, 이미지 1/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 15 단계, 이미지 2/3 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 15 단계, 이미지 3/3
    • Remove the eight 2.5mm screws with a PH0 bit.
  16. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: 16 단계, 이미지 1/1
    • After you unscrew all the screws, take the fan off to replace it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Mafdy Wahib
회원 가입일: 09/28/17
369 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G4, Nance Fall 2017 USF Tampa, Team S1-G4, Nance Fall 2017 회원
USFT-NANCE-F17S1G4
3 회원들
안내서 5개 작성하였습니다
댓글 7개
Hi, I just went through this disassembly (which is mostly great, thank you Mafdy) to replace the fans, and I wanted to point out a couple of clarifications:
Most importantly! It is NOT necessary to remove the fan/heatsink assembly from the motherboard to remove and replace the fans! Instead of proceeding with steps 15 and 16, look for tiny philips screws on the black side of the heatsink assembly which fasten each fan - 3 for one fan, 4 for the other. These are accessible once the motherboard is free from the case.
Steps 15 and 16 cause you to break the thermal compound seal on the CPU and GPU, and then proper re-assembly would mean cleaning off the old compound and correctly applying new compound before re-attaching the heatsink assembly - an unnecessary hassle just to replace the fans.
Secondly, be aware that, during steps 13-14, there are a number of additional screws and connectors that are not mentioned, that need to be removed in order to release the motherboard from the laptop housing.
Happy Fixing!
Knight9990 - 답글
fans in the final section combined with copper pipe. Can they be separated? I'm having trouble finding a fan. Where can I buy new fans.
Çağlar Gökçe - 답글
I have replaced both fans on gs60 today, and the instructions worked like charm! Steps 14-16 were unnecessary! Thx!
Konstantin Izmailov - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 26
전체 시간: 6,514
