소개
This replacement guide is difficult only because in order to replace the RAM, the motherboard need to be taken out of the device completely. However, replacing the RAM itself is not hard at all. so basically all the hard work is to unplug the motherboard completely and take it out to reach the RAM.
필요한 것
Remove the eleven 5mm screws with a Phillips #0 bit.
Remove the four 2.5mm screws with a Phillips #0 bit.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thank you very much for this guide. I’ve successfully managed to replace my RAM with 16GB module.
