소개
This guide will instruct you on how to remove the motherboard from your device.
필요한 것
Unscrew the 4 1.2mm Phillips #0 screws connecting the motherboard to the laptop case.
Disconnect the wires connecting to the motherboard to the USB ports.
Disconnect the ribbon cables connecting the keyboard, and track pad of the device.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
How to proceed with a keyboard replacement?
Had a water spill, some keys not working anymore, could this be fixable by a keyboard swap?
Can this be a n IC damage?
