주요 콘텐츠로 건너뛰기
MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement
필요한 것
  1. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: 2 단계, 이미지 1/1
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: 3 단계, 이미지 1/2 MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: 3 단계, 이미지 2/2
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, Battery: 4 단계, 이미지 1/1
    • Pull the back panel off.
  5. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: 5 단계, 이미지 1/1
    • Notice the L-shaped battery in the lower right corner of the opened laptop.
    • Disconnect the battery from the slot it is connected to. You'll need to push on the sides of the clip and pull.
  6. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: 6 단계, 이미지 1/2 MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: 6 단계, 이미지 2/2
    • Lift up the battery with your fingers and remove it from the laptop.
    • Place the battery away from the laptop in a safe spot and insert your new battery by hooking it up to the slot you previously disconnected the old battery from.
  7. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, MotherBoard: 7 단계, 이미지 1/1
    • Unscrew the 4 1.2mm Phillips #0 screws connecting the motherboard to the laptop case.
    • Disconnect the wires connecting to the motherboard to the USB ports.
    • Disconnect the ribbon cables connecting the keyboard, and track pad of the device.
  8. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: 8 단계, 이미지 1/1
    • Lift the motherboard up and out of the device casing.
  9. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, RAM Cards: 9 단계, 이미지 1/1
    • Lift the motherboard around.
    • You'll notice the RAM cards located where the red box is shown.
  10. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: 10 단계, 이미지 1/1
    • Pull the silver latches to release the RAM cards.
    • Pull out the cards and replace them with new ones.
결론
Stephen Felix
회원 가입일: 10/20/17
207 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G2, Julie Fall 2017 UMass Dartmouth, Team S2-G2, Julie Fall 2017 회원
UMASSD-JULIE-F17S2G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 512
