주요 콘텐츠로 건너뛰기
MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement
필요한 것
  1. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: 3 단계, 이미지 1/2 MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 1/1
    • Use the screwdriver to unscrew the 0.5mm Phillips #0 screw holding the Wi-Fi card in place.
  5. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: 5 단계, 이미지 1/1
    • Take out the Wi-Fi card.
    • Replace the faulty Wi-Fi card with a new Wi-Fi card.
결론
Jordan Williams
회원 가입일: 10/19/17
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G2, Julie Fall 2017 UMass Dartmouth, Team S2-G2, Julie Fall 2017 회원
UMASSD-JULIE-F17S2G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 554
