주요 콘텐츠로 건너뛰기
MSI GS63VR 6RF Stealth Pro Battery Replacement
필요한 것
  1. MSI GS63VR 6RF Stealth Pro Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Phillips screwdriver to remove the 15 screws securing the back cover.
    • Insert an opening tool or spudger in the seam and pry along the perimeter to loosen the back cover.
    • Do not insert the opening too too far into the back edge (with "Stealth" written on it), or you may damage the power LED.
    • The back cover is secured with clips. Too much pressure from the spudger can break the clips, but some flex is not dangerous.
    • Remove the back cover.
  2. MSI GS63VR 6RF Stealth Pro Battery Replacement: 2 단계, 이미지 1/1
    • Disconnect the battery by carefully pulling its connector towards the battery.
    • Pull parallel to the battery, not straight up.
  3. MSI GS63VR 6RF Stealth Pro Battery Replacement: 3 단계, 이미지 1/2 MSI GS63VR 6RF Stealth Pro Battery Replacement: 3 단계, 이미지 2/2
    • The battery is attached to the laptop with a strong adhesive.
    • Lift the battery from laptop.
    • Be careful not to bend the or puncture the battery, as that may cause a fire hazard.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 4명이 해당 안내서를 완성하였습니다.
Jay Etzkorn
회원 가입일: 09/20/17
200 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 27
전체 시간: 6,605
