주요 콘텐츠로 건너뛰기
MSI GS63VR 6RF Stealth Pro Hard Drive Replacement
필요한 것
  1. MSI GS63VR 6RF Stealth Pro Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Turn off the laptop before proceeding.
    • Unscrew the 15 screws on the bottom panel using a Phillips #00 screwdriver.
    • Pry open the back cover with a plastic prying tool.
    • Unplug the battery cable from the motherboard to prevent a ground fault. Either use your hand or a pair of tweezers to unplug the battery cable.
    • Too much pressure from the spudger can break the clips that secure the back panel, but some flex is not dangerous.
  2. MSI GS63VR 6RF Stealth Pro Hard Drive Replacement: 2 단계, 이미지 1/3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement: 2 단계, 이미지 2/3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement: 2 단계, 이미지 3/3
    • Disconnect the SATA cables from the motherboard using a plastic spudger.
    • Gently pull out the SATA cables out of the ports.
    • Grab the auburn color cable and lift up the hard drive. Slide out the hard drive while holding onto the cable.
    • Cables are fragile. Do not apply excessive force.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nabil Ranjbar
회원 가입일: 09/20/17
276 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 11
전체 시간: 3,125
