주요 콘텐츠로 건너뛰기
MSI GS63VR 6RF Stealth Pro Speakers Replacement
필요한 것
  1. MSI GS63VR 6RF Stealth Pro Speakers Replacement, Bottom Panel: 1 단계, 이미지 1/2 MSI GS63VR 6RF Stealth Pro Speakers Replacement, Bottom Panel: 1 단계, 이미지 2/2
    • Unscrew the screws located around the bottom panel with a Phillips #00 mm Screwdriver.
  2. MSI GS63VR 6RF Stealth Pro Speakers Replacement: 2 단계, 이미지 1/1
    • Carefully pry the back panel away from the laptop.
  3. MSI GS63VR 6RF Stealth Pro Speakers Replacement, Speakers: 3 단계, 이미지 1/2 MSI GS63VR 6RF Stealth Pro Speakers Replacement, Speakers: 3 단계, 이미지 2/2
    • Locate the speakers and use a plastic spudger to lift and remove them.
    • Repeat the same action for the other speaker.
  4. MSI GS63VR 6RF Stealth Pro Speakers Replacement: 4 단계, 이미지 1/3 MSI GS63VR 6RF Stealth Pro Speakers Replacement: 4 단계, 이미지 2/3 MSI GS63VR 6RF Stealth Pro Speakers Replacement: 4 단계, 이미지 3/3
    • Disconnect both speaker wires from the motherboard.
    • Be careful not to yank the cables, as this could damage them.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Judah Thomas
회원 가입일: 11/19/17
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 1,301
