소개
If you're having connectivity issues with your Stealth Pro, or simply want to upgrade your connectivity, this guide will walk you through the replacement process.
필요한 것
Unscrew the 15 screws on the bottom panel of the computer using a Phillips #00 screwdriver.
Lift open the back cover with a plastic spudger.
Gently lift the back cover away from computer. Make sure nothing is attached.
Unplug the battery cable from the motherboard to prevent a ground fault.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
Is this a msata card or a m.2 card?
Hi, do you know where I can find some new wifi cables? I broke mine (with my WiFi card) and looking to repair it
Best regards
