주요 콘텐츠로 건너뛰기
소개
If you're having connectivity issues with your Stealth Pro, or simply want an upgrade, this guide will walk you through the replacement process.
부품
지정된 부품이 없습니다.
  1. MSI GS63VR 6RF Stealth Pro WiFi Card Replacement, Wi-Fi Card: 1 단계, 이미지 1/3 MSI GS63VR 6RF Stealth Pro WiFi Card Replacement, Wi-Fi Card: 1 단계, 이미지 2/3 MSI GS63VR 6RF Stealth Pro WiFi Card Replacement, Wi-Fi Card: 1 단계, 이미지 3/3
    • Turn off the laptop and make sure it is unplugged from power before proceeding.
    • Unscrew the 15 screws on the bottom panel using a Phillips #00 screwdriver.
    • Pry open the back cover with a plastic spudger.
    • Lift the back cover away from computer. Make sure nothing is attached.
    • Unplug the battery cable from the motherboard to prevent a ground fault.
    • Too much pressure from the spudger can break the clips that secure the back panel, but some flex is not dangerous.
  2. MSI GS63VR 6RF Stealth Pro WiFi Card Replacement: 2 단계, 이미지 1/2 MSI GS63VR 6RF Stealth Pro WiFi Card Replacement: 2 단계, 이미지 2/2
    • Unscrew the single screw from the Wifi card using a Phillips #00 screwdriver.
    • Apply upward pressure on the cables using a plastic tweezer.
    • Using either your hand or the plastic tweezer, grab and wiggle the card out of the socket.
    • Pull the card upward from the slot.
    • Wifi cables are fragile.
    • To reassemble the laptop, simply reverse these steps.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Nabil Ranjbar
회원 가입일: 2017년 09월 20일
276 평판
안내서 2개 작성하였습니다
2 Comments
Is this a msata card or a m.2 card?
keith dragon - 답글
Hi, do you know where I can find some new wifi cables? I broke mine (with my WiFi card) and looking to repair it
Best regards
Bastien Allaoui - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 82
전체 시간: 3,286
