주요 콘텐츠로 건너뛰기
MSI GS63VR 7RF Stealth Pro Hard Drive Replacement
필요한 것
  1. MSI GS63VR 7RF Stealth Pro Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use the spudger to separate the back plate from the rest of the computer with the screen up like in the picture.
    • Once the back plate is loose, close the screen for an easier time properly removing it.
  2. MSI GS63VR 7RF Stealth Pro Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips Head #1 screwdriver, unscrew the 15 screws on the bottom of the device
    • After all the screws are unscrewed, remove the bottom plate. If this is the first time that you are removing this back cover, the last screw is hidden under the "factory seal" label. You will need to break that label to reach that screw.
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go.
    • Another method for keeping track of all the screws would be to secure each removed screw near the hole that it was removed from with a piece of painters or masking tape. This type of tape is easy to remove from the fuzzy surface but strong enough to secure the screw to the back cover.
  3. MSI GS63VR 7RF Stealth Pro Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 MSI GS63VR 7RF Stealth Pro Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 MSI GS63VR 7RF Stealth Pro Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Locate the battery.
    • Wedge the spudger underneath the battery, and apply pressure to lift it away from the rest of the device.
    • Gently pull and wiggle the multiple colored wired connector out from the socket.
    • If you are removing the original battery, the back has a couple foam strips that were installed for cushioning. Those can be carefully removed and placed on the new replacement battery, but it is not necessary.
  4. MSI GS63VR 7RF Stealth Pro Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 1개 MSI GS63VR 7RF Stealth Pro Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 2개
    • Locate the hard drive.
    • Using a spudger lift the ribbon cable connector.
  5. MSI GS63VR 7RF Stealth Pro Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 MSI GS63VR 7RF Stealth Pro Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tweezers to lift the back tab and pull it back until the ribbon cable disconnects.
    • Wedge the spudger between the hard drive and the device and apply pressure to pry the two apart, and then remove the hard drive.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Chris Gifford
회원 가입일: 10/20/17
995 평판
안내서 3개를 작성함
UMass Dartmouth, Team S2-G1, Julie Fall 2017 UMass Dartmouth, Team S2-G1, Julie Fall 2017 회원
UMASSD-JULIE-F17S2G1
3 회원들
안내서 5개를 작성함
3가이드 댓글
Could you please give more details on how to remove the backplate in step 1? It is the most fragile part in the whole laptop and the first one to get damaged/broken as well. Some more pictures of the process would be great.
Ian - 답글
I agree with you… i would like some more pictures on how to put the new SSD or HDD in and put everything back to
Aaron Orme -
I just did the first step of loosening screen with spudger - not sure if needed or not, but I did it and some metal things popped. Then unscrewed all the screws and left them in place and propped just the back of the cover partially open. Hard drive then just came out, no need to touch the battery. Switched the ribbon connector to 1 TB SSD, screwed the cover back on and everything worked. Now cloning old drive with Macrium Reflect Free Edition. Love the tools in replacement kit for those who don’t already have a USB-3 enclosure/a full set of repair essentials. Also things organized in a box called iFixit are less likely to lose peaces or be misplaced.
Oleg Kibirev - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 45
전체 시간: 10,624
