주요 콘텐츠로 건너뛰기
MSI GS66 Stealth 11UE-007 Speakers Replacement
필요한 것
  1. MSI GS66 Stealth 11UE-007 Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device.
  2. MSI GS66 Stealth 11UE-007 Speakers Replacement: 2 단계, 이미지 1/1
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
  3. MSI GS66 Stealth 11UE-007 Speakers Replacement: 3 단계, 이미지 1/1
    • Remove eight 10 mm Phillips #1 screws.
  4. MSI GS66 Stealth 11UE-007 Speakers Replacement: 4 단계, 이미지 1/1
    • Remove one 7 mm Phillips #1 screw from the center bottom of backplate.
  5. MSI GS66 Stealth 11UE-007 Speakers Replacement: 5 단계, 이미지 1/3 MSI GS66 Stealth 11UE-007 Speakers Replacement: 5 단계, 이미지 2/3 MSI GS66 Stealth 11UE-007 Speakers Replacement: 5 단계, 이미지 3/3
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
  6. MSI GS66 Stealth 11UE-007 Speakers Replacement: 6 단계, 이미지 1/1
    • Peal back metallic tape on the right side of the USB port.
  7. MSI GS66 Stealth 11UE-007 Speakers Replacement: 7 단계, 이미지 1/2 MSI GS66 Stealth 11UE-007 Speakers Replacement: 7 단계, 이미지 2/2
    • Remove three 6 mm Phillips #1 screws.
  8. MSI GS66 Stealth 11UE-007 Speakers Replacement: 8 단계, 이미지 1/1
    • Use the tip of the spudger or your fingernail to gently push out the white connector.
  9. MSI GS66 Stealth 11UE-007 Speakers Replacement: 9 단계, 이미지 1/2 MSI GS66 Stealth 11UE-007 Speakers Replacement: 9 단계, 이미지 2/2
    • Remove the battery from the device.
  10. MSI GS66 Stealth 11UE-007 Speakers Replacement, Speakers: 10 단계, 이미지 1/2 MSI GS66 Stealth 11UE-007 Speakers Replacement, Speakers: 10 단계, 이미지 2/2
    • Disconnect the speaker power using the tip of the spudger or fingernail to gently push on either side of the connector.
  11. MSI GS66 Stealth 11UE-007 Speakers Replacement: 11 단계, 이미지 1/2 MSI GS66 Stealth 11UE-007 Speakers Replacement: 11 단계, 이미지 2/2
    • Lift up the clip using the spudger.
    • Pull out the ribbon cable away from the clips.
  12. MSI GS66 Stealth 11UE-007 Speakers Replacement: 12 단계, 이미지 1/2 MSI GS66 Stealth 11UE-007 Speakers Replacement: 12 단계, 이미지 2/2
    • Remove the wire from the channel it's sitting in.
  13. MSI GS66 Stealth 11UE-007 Speakers Replacement: 13 단계, 이미지 1/3 MSI GS66 Stealth 11UE-007 Speakers Replacement: 13 단계, 이미지 2/3 MSI GS66 Stealth 11UE-007 Speakers Replacement: 13 단계, 이미지 3/3
    • Lift up the left and right speakers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Robinson
회원 가입일: 09/06/23
1,057 평판
안내서 6개 작성하였습니다
University of Memphis, Team 1-4, Sneed Fall 2023 University of Memphis, Team 1-4, Sneed Fall 2023 회원
UM-SNEED-F23S1G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 22
전체 시간: 122
