주요 콘텐츠로 건너뛰기
MSI GT62VR 6RD Dominator Battery Replacement
필요한 것
  1. MSI GT62VR 6RD Dominator Battery Replacement, Battery: 1 단계, 이미지 1/2 MSI GT62VR 6RD Dominator Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
  2. MSI GT62VR 6RD Dominator Battery Replacement: 2 단계, 이미지 1/2 MSI GT62VR 6RD Dominator Battery Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
    • The laptop cover will break if it is being handled roughly.
    • Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
    • Remove the back plate.
  3. MSI GT62VR 6RD Dominator Battery Replacement: 3 단계, 이미지 1/3 MSI GT62VR 6RD Dominator Battery Replacement: 3 단계, 이미지 2/3 MSI GT62VR 6RD Dominator Battery Replacement: 3 단계, 이미지 3/3
    • Locate the battery.
    • The wires are located at the back end of the battery and covered in tape.
    • Remove the tape covering the battery connector.
    • Place your hands at the corners of the wires.
    • Pull upward from the back end of the battery where the wires are located.
    • Remove the battery.
결론
Rebekah Johnson
회원 가입일: 09/18/18
147 평판
안내서 1개 작성함
University of North Texas, Team S4-G1, Raign Fall 2018 University of North Texas, Team S4-G1, Raign Fall 2018 회원
UNT-RAIGN-F18S4G1
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Can i use it using chargine cable even if i remove rhe battery?
Tabs XXIV - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,953
