이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the six screws on the back plate of the laptop using a JIS #0 screwdriver.
Insert a plastic opening tool into the seam of the back cover
Pry the cover up until clips release.
Slide the plastic opening tool around the laptop until cover is fully removed.
Remove the two screws securing the hard drive to the laptop.
Lightly lift the hard drive up by grasping the silver bracket that secures it to the laptop.
Wiggle it backwards slowly until it is unplugged.
Slide out from under the cover towards the battery.
