주요 콘텐츠로 건너뛰기
MSI GT62VR 6RD Dominator M.2 SSD Replacement
필요한 것
  1. MSI GT62VR 6RD Dominator M.2 SSD Replacement, M.2 SSD: 1 단계, 이미지 1/2 MSI GT62VR 6RD Dominator M.2 SSD Replacement, M.2 SSD: 1 단계, 이미지 2/2
    • Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator M.2 SSD Replacement: 2 단계, 이미지 1/3 MSI GT62VR 6RD Dominator M.2 SSD Replacement: 2 단계, 이미지 2/3 MSI GT62VR 6RD Dominator M.2 SSD Replacement: 2 단계, 이미지 3/3
    • Insert the plastic opening tool into the seam on the backplate of the laptop.
    • A popping sound will be produced from your device while you remove the backplate.
    • Pry the back plate up.
    • Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
  3. MSI GT62VR 6RD Dominator M.2 SSD Replacement: 3 단계, 이미지 1/2 MSI GT62VR 6RD Dominator M.2 SSD Replacement: 3 단계, 이미지 2/2
    • Remove the single 1.2mm screw securing the SSD to the laptop using the JIS #0 screwdriver.
  4. MSI GT62VR 6RD Dominator M.2 SSD Replacement: 4 단계, 이미지 1/2 MSI GT62VR 6RD Dominator M.2 SSD Replacement: 4 단계, 이미지 2/2
    • Remove the old SSD, then insert and screw in the new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Berberich
회원 가입일: 09/18/18
266 평판
안내서 1개 작성함
University of North Texas, Team S4-G1, Raign Fall 2018 University of North Texas, Team S4-G1, Raign Fall 2018 회원
UNT-RAIGN-F18S4G1
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Isn’t that an M.2 Drive not a GPU? the GPU is in the top right. under the heat pipes.
Will Rogers - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 1,270
