주요 콘텐츠로 건너뛰기
MSI GT70 MS-1763 Cooling Fan Replacement
필요한 것
  1. MSI GT70 MS-1763 Cooling Fan Replacement, Battery: 1 단계, 이미지 1/2 MSI GT70 MS-1763 Cooling Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Power off the laptop and turn it over.
  2. MSI GT70 MS-1763 Cooling Fan Replacement: 2 단계, 이미지 1/2 MSI GT70 MS-1763 Cooling Fan Replacement: 2 단계, 이미지 2/2
    • Release the safety latches that hold the battery in place. The left latch will stay moved up, while the right side is spring activated and will have to be held.
  3. MSI GT70 MS-1763 Cooling Fan Replacement: 3 단계, 이미지 1/2 MSI GT70 MS-1763 Cooling Fan Replacement: 3 단계, 이미지 2/2
    • While holding up the left latch, use a Jimmy and slide the old battery out of its compartment.
  4. MSI GT70 MS-1763 Cooling Fan Replacement, Hard Drive: 4 단계, 이미지 1/2 MSI GT70 MS-1763 Cooling Fan Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Remove all twelve 4 mm Phillips #0 screws from the back of the laptop.
    • Remove the back cover.
  5. MSI GT70 MS-1763 Cooling Fan Replacement: 5 단계, 이미지 1/1
    • Remove the rubber spacer holding the hard drive secure.
  6. MSI GT70 MS-1763 Cooling Fan Replacement: 6 단계, 이미지 1/2 MSI GT70 MS-1763 Cooling Fan Replacement: 6 단계, 이미지 2/2
    • Slide the hard drive to the left, removing it from its bay.
  7. MSI GT70 MS-1763 Cooling Fan Replacement, Cooling Fan: 7 단계, 이미지 1/1
    • Remove the single 3 mm screw holding the cooling fan in place with a Phillips #0 screwdriver.
  8. MSI GT70 MS-1763 Cooling Fan Replacement: 8 단계, 이미지 1/1
    • Disconnect the cable supplying power to the fan.
  9. MSI GT70 MS-1763 Cooling Fan Replacement: 9 단계, 이미지 1/1
    • Remove the fan by lifting straight up.
결론
Cruz Uribe
회원 가입일: 08/22/19
267 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 1,170
