주요 콘텐츠로 건너뛰기
MSI GT70 MS-1763 Keyboard Replacement
필요한 것
  1. MSI GT70 MS-1763 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 MSI GT70 MS-1763 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Power off the laptop and turn it over.
  2. MSI GT70 MS-1763 Keyboard Replacement: 2 단계, 이미지 1/2 MSI GT70 MS-1763 Keyboard Replacement: 2 단계, 이미지 2/2
    • Release the safety latches that hold the battery in place. The left latch will stay moved up, while the right side is spring activated and will have to be held.
  3. MSI GT70 MS-1763 Keyboard Replacement: 3 단계, 이미지 1/2 MSI GT70 MS-1763 Keyboard Replacement: 3 단계, 이미지 2/2
    • While holding up the left latch, use a Jimmy and slide the old battery out of its compartment.
  4. MSI GT70 MS-1763 Keyboard Replacement, Hard Drive: 4 단계, 이미지 1/2 MSI GT70 MS-1763 Keyboard Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Remove all twelve 4 mm Phillips #0 screws from the back of the laptop.
    • Remove the back cover.
  5. MSI GT70 MS-1763 Keyboard Replacement: 5 단계, 이미지 1/1
    • Remove the rubber spacer holding the hard drive secure.
  6. MSI GT70 MS-1763 Keyboard Replacement: 6 단계, 이미지 1/2 MSI GT70 MS-1763 Keyboard Replacement: 6 단계, 이미지 2/2
    • Slide the hard drive to the left, removing it from its bay.
  7. MSI GT70 MS-1763 Keyboard Replacement, Keyboard: 7 단계, 이미지 1/3 MSI GT70 MS-1763 Keyboard Replacement, Keyboard: 7 단계, 이미지 2/3 MSI GT70 MS-1763 Keyboard Replacement, Keyboard: 7 단계, 이미지 3/3
    • Using a Jimmy, remove the outer cover around the keyboard.
    • Remove the ribbon cable from the ZIF connector on the underside of the top cover.
  8. MSI GT70 MS-1763 Keyboard Replacement: 8 단계, 이미지 1/2 MSI GT70 MS-1763 Keyboard Replacement: 8 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the five 3 mm screws at the top of the keyboard.
  9. MSI GT70 MS-1763 Keyboard Replacement: 9 단계, 이미지 1/1
    • Flip the keyboard back and disconnect the keyboard cable.
  10. MSI GT70 MS-1763 Keyboard Replacement: 10 단계, 이미지 1/3 MSI GT70 MS-1763 Keyboard Replacement: 10 단계, 이미지 2/3 MSI GT70 MS-1763 Keyboard Replacement: 10 단계, 이미지 3/3
    • Flip the laptop over and disconnect the data cable from the ZIF connector on the bottom right.
    • You can now turn the laptop back over and remove the keyboard.
결론
Bhrett Farrar
회원 가입일: 08/22/19
109 평판
안내서 1개 작성함
댓글 한 개
Mine is the Cyberbuypower rebadge of this model. And you only need to remove the two keyboards screws on the bottom. And then the top button board (called outer cover here)
Even here I don’t see why you have to remove all those screws.
garegin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 24
전체 시간: 2,145
