주요 콘텐츠로 건너뛰기
MSI GT70 MS-1763 RAM Replacement
필요한 것
  1. MSI GT70 MS-1763 RAM Replacement, Battery: 1 단계, 이미지 1/2 MSI GT70 MS-1763 RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Power off the laptop and turn it over.
  2. MSI GT70 MS-1763 RAM Replacement: 2 단계, 이미지 1/2 MSI GT70 MS-1763 RAM Replacement: 2 단계, 이미지 2/2
    • Release the safety latches that hold the battery in place. The left latch will stay moved up, while the right side is spring activated and will have to be held.
  3. MSI GT70 MS-1763 RAM Replacement: 3 단계, 이미지 1/2 MSI GT70 MS-1763 RAM Replacement: 3 단계, 이미지 2/2
    • While holding up the left latch, use a Jimmy and slide the old battery out of its compartment.
  4. MSI GT70 MS-1763 RAM Replacement, Hard Drive: 4 단계, 이미지 1/2 MSI GT70 MS-1763 RAM Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Remove all twelve 4 mm Phillips #0 screws from the back of the laptop.
    • Remove the back cover.
  5. MSI GT70 MS-1763 RAM Replacement: 5 단계, 이미지 1/1
    • Remove the rubber spacer holding the hard drive secure.
  6. MSI GT70 MS-1763 RAM Replacement: 6 단계, 이미지 1/2 MSI GT70 MS-1763 RAM Replacement: 6 단계, 이미지 2/2
    • Slide the hard drive to the left, removing it from its bay.
  7. MSI GT70 MS-1763 RAM Replacement, Keyboard: 7 단계, 이미지 1/3 MSI GT70 MS-1763 RAM Replacement, Keyboard: 7 단계, 이미지 2/3 MSI GT70 MS-1763 RAM Replacement, Keyboard: 7 단계, 이미지 3/3
    • Using a Jimmy, remove the outer cover around the keyboard.
    • Remove the ribbon cable from the ZIF connector on the underside of the top cover.
  8. MSI GT70 MS-1763 RAM Replacement: 8 단계, 이미지 1/2 MSI GT70 MS-1763 RAM Replacement: 8 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the five 3 mm screws at the top of the keyboard.
  9. MSI GT70 MS-1763 RAM Replacement: 9 단계, 이미지 1/1
    • Flip the keyboard back and disconnect the keyboard cable.
  10. MSI GT70 MS-1763 RAM Replacement: 10 단계, 이미지 1/3 MSI GT70 MS-1763 RAM Replacement: 10 단계, 이미지 2/3 MSI GT70 MS-1763 RAM Replacement: 10 단계, 이미지 3/3
    • Flip the laptop over and disconnect the data cable from the ZIF connector on the bottom right.
    • You can now turn the laptop back over and remove the keyboard.
  11. MSI GT70 MS-1763 RAM Replacement, RAM: 11 단계, 이미지 1/1
    • Pull back the black film, which covers the ram.
  12. MSI GT70 MS-1763 RAM Replacement: 12 단계, 이미지 1/2 MSI GT70 MS-1763 RAM Replacement: 12 단계, 이미지 2/2
    • Pull the safety latches on either side of the RAM away from each other.
    • The RAM should pop up at an angle from the motherboard when it has cleared the latches.
    • Remove the RAM, maintaining the angle at which it rests.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brad Dunlap
회원 가입일: 08/22/19
529 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 19
전체 시간: 1,514
