소개
If your MSI GT70 MS-1763 has memory issues – undetected RAM, memory crashes, startup failure, or simply running out of memory – this guide will provide instructions for replacing the RAM.
Before using this guide, be sure the computer issues are related to the RAM. If you are having random crashes, boot your computer in safe mode and see if the issue persists. There is also software such as MemTest86 which diagnoses your computer’s RAM to confirm the issue is related to the RAM.
Before beginning, make sure to completely power off your device and disconnect it from the charger.
필요한 것
Remove all twelve 4 mm Phillips #0 screws from the back of the laptop.
Remove the back cover.
Using a Jimmy, remove the outer cover around the keyboard.
Remove the ribbon cable from the ZIF connector on the underside of the top cover.
다른 한 분이 해당 안내서를 완성하였습니다.
