주요 콘텐츠로 건너뛰기
MSI GT70 MS-1763 Screen Replacement
필요한 것
  1. MSI GT70 MS-1763 Screen Replacement, Battery: 1 단계, 이미지 1/2 MSI GT70 MS-1763 Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Power off the laptop and turn it over.
  2. MSI GT70 MS-1763 Screen Replacement: 2 단계, 이미지 1/2 MSI GT70 MS-1763 Screen Replacement: 2 단계, 이미지 2/2
    • Release the safety latches that hold the battery in place. The left latch will stay moved up, while the right side is spring activated and will have to be held.
  3. MSI GT70 MS-1763 Screen Replacement: 3 단계, 이미지 1/2 MSI GT70 MS-1763 Screen Replacement: 3 단계, 이미지 2/2
    • While holding up the left latch, use a Jimmy and slide the old battery out of its compartment.
  4. MSI GT70 MS-1763 Screen Replacement, Screen: 4 단계, 이미지 1/2 MSI GT70 MS-1763 Screen Replacement, Screen: 4 단계, 이미지 2/2
    • Remove the rubber guards covering the two 3mm screws on the bottom of the screen. Next, remove the screws with a Phillips #0 screwdriver.
  5. MSI GT70 MS-1763 Screen Replacement: 5 단계, 이미지 1/2 MSI GT70 MS-1763 Screen Replacement: 5 단계, 이미지 2/2
    • Using a Jimmy, remove the outside cover around the screen.
  6. MSI GT70 MS-1763 Screen Replacement: 6 단계, 이미지 1/3 MSI GT70 MS-1763 Screen Replacement: 6 단계, 이미지 2/3 MSI GT70 MS-1763 Screen Replacement: 6 단계, 이미지 3/3
    • Remove the six Phillips #0 screws holding the screen in place.
    • Separate screen from the assembly with a Jimmy.
    • Remove the display cable from its connector on the back of the screen.
    • Remove the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cruz Uribe
회원 가입일: 08/22/19
267 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 23
전체 시간: 1,024
