주요 콘텐츠로 건너뛰기
MSI GT72 2QE Dominator Pro CD Drive Replacement
필요한 것
  1. MSI GT72 2QE Dominator Pro CD Drive Replacement, CD Drive: 1 단계, 이미지 1/2 MSI GT72 2QE Dominator Pro CD Drive Replacement, CD Drive: 1 단계, 이미지 2/2
    • Remove the indicated seven (7) 6 mm Phillips #0 screws for the back cover.
    • The same PHO screwdriver bit can be used throughout all the steps.
  2. MSI GT72 2QE Dominator Pro CD Drive Replacement: 2 단계, 이미지 1/2 MSI GT72 2QE Dominator Pro CD Drive Replacement: 2 단계, 이미지 2/2
    • Lift the back cover using the tab to expose the hardware beneath.
  3. MSI GT72 2QE Dominator Pro CD Drive Replacement: 3 단계, 이미지 1/3 MSI GT72 2QE Dominator Pro CD Drive Replacement: 3 단계, 이미지 2/3 MSI GT72 2QE Dominator Pro CD Drive Replacement: 3 단계, 이미지 3/3
    • Remove the indicated 5mm Phillips #0 screw.
    • This is the only screw holding the CD drive in place. Do not lose it.
  4. MSI GT72 2QE Dominator Pro CD Drive Replacement: 4 단계, 이미지 1/1
    • Using the plastic opening tool, pull out the CD drive.
  5. MSI GT72 2QE Dominator Pro CD Drive Replacement: 5 단계, 이미지 1/2 MSI GT72 2QE Dominator Pro CD Drive Replacement: 5 단계, 이미지 2/2
    • Remove the indicated 4mm Phillips #0 screw and metal hinge.
  6. MSI GT72 2QE Dominator Pro CD Drive Replacement: 6 단계, 이미지 1/2 MSI GT72 2QE Dominator Pro CD Drive Replacement: 6 단계, 이미지 2/2
    • Remove the three (3) indicated 2mm Phillips #0 screws.
  7. MSI GT72 2QE Dominator Pro CD Drive Replacement: 7 단계, 이미지 1/2 MSI GT72 2QE Dominator Pro CD Drive Replacement: 7 단계, 이미지 2/2
    • Lift metal cover gently, using the tab like indent located where the arrow is pointed.
    • This should expose the inside of the CD drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ankit Maurya
회원 가입일: 04/18/17
201 평판
안내서 1개 작성함
Cal Poly, Team S17-G2, Banghart Spring 2017 Cal Poly, Team S17-G2, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G2
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 29
전체 시간: 1,739
