주요 콘텐츠로 건너뛰기
MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement
필요한 것
  1. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement, Hard Drive and SSD: 1 단계, 이미지 1/2 MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement, Hard Drive and SSD: 1 단계, 이미지 2/2
    • Remove the seven 6mm #0 Phillips Head screws on the bottom of the device.
    • Remove the bottom to access the inside.
  2. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: 2 단계, 이미지 1/2 MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: 2 단계, 이미지 2/2
    • Disconnect the SATA cable from the hard drive.
  3. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: 3 단계, 이미지 1/1
    • Pull out the hard drive.
  4. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: 4 단계, 이미지 1/2 MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: 4 단계, 이미지 2/2
    • Remove the two 6mm #0 Phillips head screws securing the two SSDs.
  5. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: 5 단계, 이미지 1/1
    • Pull the SSDs away from its slot.
    • Be sure to pull parallel to the PCB. Do not pull upward at an angle.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Colin Harrop
회원 가입일: 04/20/17
164 평판
안내서 1개 작성함
Cal Poly, Team S17-G2, Banghart Spring 2017 Cal Poly, Team S17-G2, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G2
5 회원들
안내서 7개 작성하였습니다
댓글 한 개
Good evening how to get a laptop battery with shipping to Saudi Arabia
rajh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 26
전체 시간: 5,329
