주요 콘텐츠로 건너뛰기
MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement
필요한 것
  1. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement, CPU/GPU Chip: 1 단계, 이미지 1/3 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement, CPU/GPU Chip: 1 단계, 이미지 2/3 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement, CPU/GPU Chip: 1 단계, 이미지 3/3
    • Remove the four screws from the rear laptop cover using the Phillips #0 screwdriver. The screws are 0.5 inches long.
    • Use the black nylon spudger to pry the cover off the laptop.
  2. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 2 단계, 이미지 1/3 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 2 단계, 이미지 2/3 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 2 단계, 이미지 3/3
    • Unplug the battery plug from the unit. Lift the battery out of the housing by prying it from the adhesive using the black nylon spudger.
  3. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 3 단계, 이미지 1/1
    • Remove the screws using the Phillips #0 screwdriver. Disconnect the left side fan from the unit as shown. The screws are 0.25 inches long.
  4. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 4 단계, 이미지 1/2 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 4 단계, 이미지 2/2
    • Unscrew the CPU cooling plate using the Phillips #0 screwdriver. Lift the cooling pipes away from the unit. Screws are 0.15625 inches long.
    • Unscrew both standoff nuts from the chip using the Phillips #0 screwdriver. Then lift and remove the unit from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Wester
회원 가입일: 08/31/18
424 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 1,335
