이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Central processing units and Graphic processing units can be a crucial component to your computer system. Both of these units can help with the overall display and speed of the computer. Over time CPU and GPU will become outdated or be corrupted. This will lead to the replacement of the CPU and GPU.
필요한 것
Remove the four screws from the rear laptop cover using the Phillips #0 screwdriver. The screws are 0.5 inches long.
Use the black nylon spudger to pry the cover off the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
