주요 콘텐츠로 건너뛰기
MSI GT75VR 7RF Titan Pro RAM Card Replacement
필요한 것
  1. MSI GT75VR 7RF Titan Pro RAM Card Replacement, RAM Card: 1 단계, 이미지 1/1
    • Unscrew each of the four screws using the Phillips #0 head on the back of the laptop case. The screws are 0.5 inches in length.
  2. MSI GT75VR 7RF Titan Pro RAM Card Replacement: 2 단계, 이미지 1/2 MSI GT75VR 7RF Titan Pro RAM Card Replacement: 2 단계, 이미지 2/2
    • Pop the back cover off of the laptop using the black nylon spudger.
  3. MSI GT75VR 7RF Titan Pro RAM Card Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery cable.
  4. MSI GT75VR 7RF Titan Pro RAM Card Replacement: 4 단계, 이미지 1/2 MSI GT75VR 7RF Titan Pro RAM Card Replacement: 4 단계, 이미지 2/2
    • Pry the battery pack up with the black nylon spudger.
  5. MSI GT75VR 7RF Titan Pro RAM Card Replacement: 5 단계, 이미지 1/1
    • Pop the metal tabs on each side of the RAM using the black nylon spudger.
  6. MSI GT75VR 7RF Titan Pro RAM Card Replacement: 6 단계, 이미지 1/1
    • Lift and remove RAM card by hand. Replace each RAM card and test them individually. If your computer encounters a RAM error with only one card inserted, you can confirm that card is corrupted.
결론
Jack Crumpton
회원 가입일: 08/31/18
241 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 642
