주요 콘텐츠로 건너뛰기
MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement
필요한 것
  1. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement, SSD/Hard Drive: 1 단계, 이미지 1/1
    • Remove the four rear screws using the Phillips #0 screwdriver from the laptop as shown. The screws are 0.5 inches long.
  2. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 2 단계, 이미지 1/2 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 2 단계, 이미지 2/2
    • Using the black nylon spudger, carefully remove the rear cover from the laptop.
  3. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 3 단계, 이미지 1/3 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 3 단계, 이미지 2/3 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 3 단계, 이미지 3/3
    • Carefully unplug the battery and remove it from the laptop. This will be held down with adhesive, but can be safely removed once unplugged.
  4. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 4 단계, 이미지 1/2 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 4 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove each screw from the heatsink and remove it.
  5. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 5 단계, 이미지 1/3 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 5 단계, 이미지 2/3 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 5 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove each screw from the SSD card units, then unplug and remove them. The screws are 0.25 inches long.
  6. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 6 단계, 이미지 1/2 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: 6 단계, 이미지 2/2
    • Remove all screws from the back of the hard drive using the Phillips #0 screwdriver, then lift up and unplug the unit. Screws are 0.15625 inches long.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Wester
회원 가입일: 08/31/18
424 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 1,541
