주요 콘텐츠로 건너뛰기
MSI MS-1782 Back Cover Replacement
필요한 것
  1. MSI MS-1782 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Back Cover Replacement: 2 단계, 이미지 1/3 MSI MS-1782 Back Cover Replacement: 2 단계, 이미지 2/3 MSI MS-1782 Back Cover Replacement: 2 단계, 이미지 3/3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
결론
Joshua Pizzo
회원 가입일: 03/08/23
438 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 233
