주요 콘텐츠로 건너뛰기
MSI MS-1782 Wi-Fi Card Replacement
필요한 것
  1. MSI MS-1782 Wi-Fi Card Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Wi-Fi Card Replacement: 2 단계, 이미지 1/3 MSI MS-1782 Wi-Fi Card Replacement: 2 단계, 이미지 2/3 MSI MS-1782 Wi-Fi Card Replacement: 2 단계, 이미지 3/3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: 3 단계, 이미지 1/3 MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: 3 단계, 이미지 2/3 MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: 3 단계, 이미지 3/3
    • Use the flat end of a spudger to detach the two antenna cables from the Wi-Fi card.
  4. MSI MS-1782 Wi-Fi Card Replacement: 4 단계, 이미지 1/2 MSI MS-1782 Wi-Fi Card Replacement: 4 단계, 이미지 2/2
    • Remove the 5 mm screw holding the Wi-Fi card in place with a JIS #1 screwdriver.
  5. MSI MS-1782 Wi-Fi Card Replacement: 5 단계, 이미지 1/2 MSI MS-1782 Wi-Fi Card Replacement: 5 단계, 이미지 2/2
    • Remove the Wi-Fi card at its angle.
결론
To reassemble your device, follow these instructions in reverse order and make sure you put the antenna wires back in the correct order.
A'kia
회원 가입일: 03/08/23
193 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 111
