주요 콘텐츠로 건너뛰기
MSI PE70 6QE-035US Fan Replacement
필요한 것
  1. MSI PE70 6QE-035US Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Start by flipping the device over to the backside.
    • Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
  2. MSI PE70 6QE-035US Fan Replacement: 2 단계, 이미지 1/1
    • after the back of the laptop is off, unscrew all the black and silver screws holding in the heat sink and fan covers.
    • There should be 8 silver, 6 black, and 14 screws in total.
  3. MSI PE70 6QE-035US Fan Replacement: 3 단계, 이미지 1/2 MSI PE70 6QE-035US Fan Replacement: 3 단계, 이미지 2/2
    • disconnect the wires that go from the fans to the motherboard.
    • then remove the fans from the mother board.
결론
Wade Johnson
회원 가입일: 10/02/23
466 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 12
전체 시간: 73
