소개
Are you having trouble running programs and require a RAM replacement? Or maybe just looking to replace your current RAM sticks with others? This guide will show you all the steps on how to do so. All you will need is the J0 size bit, an Ifixit screwdriver, and any hard surface ground or area that will not create static electricity.
필요한 것
거의 끝나갑니다!
To reassemble your device, follow these instructions in reverse order
결론
다른 2명이 해당 안내서를 완성하였습니다.
