주요 콘텐츠로 건너뛰기
MSI PR600 MS-16372 Battery Replacement
  1. MSI PR600 MS-16372 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • First, turn off the computer and unplug the power cord.
    • If laptop is not unplugged from the power cord, you could be at risk of electric shock.
  2. MSI PR600 MS-16372 Battery Replacement: 2 단계, 이미지 1/1
    • Flip laptop over so that you are looking at the bottom of the laptop.
    • Put your left pointer finger on the switch labeled "Battery lock" and your right pointer finger on the switch labeled "Release".
  3. MSI PR600 MS-16372 Battery Replacement: 3 단계, 이미지 1/1
    • Switch the tab labeled "Battery lock" to the unlocked position.
    • Slide the tab labeled "Release" to the right and hold it down.
    • While holding the "Release" tab to the right, slide the battery out with your left hand.
결론
Lauren Mewes
회원 가입일: 10/21/18
361 평판
안내서 3개 작성하였습니다
UC Davis, Team S4-G8, Lore Fall 2018 UC Davis, Team S4-G8, Lore Fall 2018 회원
UCD-LORE-F18S4G8
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 308
