주요 콘텐츠로 건너뛰기
MSI PR600 MS-16372 Key Replacement
필요한 것
  1. MSI PR600 MS-16372 Key Replacement, Key: 1 단계, 이미지 1개 중 1개
    • Before you begin this replacement, make sure to turn the computer off to prevent future problems from occurring.
    • Start by flipping the laptop upside down and shake it gently to release excess debris.
  2. MSI PR600 MS-16372 Key Replacement: 2 단계, 이미지 1개 중 1개
    • Place flathead screwdriver underneath the faulty key.
    • Lift the flathead screwdriver upwards until you hear a click and it releases off the keyboard.
  3. MSI PR600 MS-16372 Key Replacement: 3 단계, 이미지 1개 중 1개
    • Gently brush off any loose particles that could be found underneath the key.
  4. MSI PR600 MS-16372 Key Replacement: 4 단계, 이미지 1개 중 1개
    • Align key to the center of the button and press down until you hear it click.
    • If you do not apply enough pressure the key will not fully reattach, so make sure you press hard enough.
결론
작성자
1다른 기여자 명과 함께
Lauren Mewes
회원 가입일: 10/21/18
388 평판
안내서 3개를 작성함
UC Davis, Team S4-G8, Lore Fall 2018 UC Davis, Team S4-G8, Lore Fall 2018 회원
UCD-LORE-F18S4G8
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 425
