주요 콘텐츠로 건너뛰기
MSI VR601 WiFi card Replacement
필요한 것
  1. MSI VR601 WiFi card Replacement, Open the back cover: 1 단계, 이미지 1/2 MSI VR601 WiFi card Replacement, Open the back cover: 1 단계, 이미지 2/2
    • Start by taking out the battery and charger. No power should be connected.
    • Unscrew the 4 Phillips #1 screws marked in the photo.
    • This screw is hidden under the Warranty void sticker!
    • All screws are the same length, so don't worry about mixing them up
    • Use a spudger or your finger to gently but firmly open the cover.
    • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
  2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: 2 단계, 이미지 1/2 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: 2 단계, 이미지 2/2
    • The WiFi card has two antenna cables (one white and one black).
    • Use a spudger to carefully unhook the antenna contacts.
    • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
  3. MSI VR601 WiFi card Replacement, Replace WiFi card: 3 단계, 이미지 1/1
    • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
    • In my case I only had a direct replacement, which only supports 802.11b/g standards.
결론
Geir Ove Andersen
회원 가입일: 06/06/22
7,740 평판
안내서 5개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,541개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 196
