주요 콘텐츠로 건너뛰기
Mac Powerbook 140 Battery Replacement
필요한 것
  1. Mac Powerbook 140 Battery  Replacement, Aquire Battery: 1 단계, 이미지 1/1
    • Begin by locating the correct type of battery. A simple internet search or a glance at Amazon.com should bring the right results. BE SURE THAT THE BATTERY IS COMPATIBLE WITH THE COMPUTER. Not doing so could result in injury.
  2. Mac Powerbook 140 Battery  Replacement, Remove Original Battery: 2 단계, 이미지 1/1
    • Slide the battery panel ( or switch, depending on the battery) on the left side of the computer so the battery is in the "Unlocked" position. Pull the battery straight out. Put in the new battery and slide the panel/switch to the "Locked" position.
결론
It is not required, but I always find it useful to save the old battery, lest you need it later. Unless the battery is leaking, or poses some other health/safety issue(in which case dispose of it in the proper manner), store it in a battery-safe environment.
다른 2명이 해당 안내서를 완성하였습니다.
Jack
회원 가입일: 10/23/15
786 평판
안내서 3개 작성하였습니다
댓글 한 개
I can’t find a replacement battery anywhere, they’re either out of stock or in another powerbook on ebay and those cost $80 with the chance that the battery in them is dead too.
BCG04 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 22
전체 시간: 1,643
